temperature huile / clim
17 réponses à ce sujet
Guest_pywash_*
Guest_pywash_*
Salut a tous
J'ai entendu dire que l'on pouvais voir la température d'huile sur les boxster 1998 et 1999 via la clim.
est ce que c'est vrai ? et si oui comment fait on ?
merci a+++ les porschman
  • 40399 messages
Oui c'est vraie! Je te retrouve la procédure.. On peut lire des tas d'autres chose ainsi...
Edelrot
Edelrot
  • 10334 messages
  • Kilométrage:118K km
Tout à fait, ce n'est pas une légende urbaine. ;)
Voici la procédure en anglais.
The AC Climatronic unit is actually manufactured by Audi. There is some sort of serial data stream (not CAN) that allows the AC unit to display engine parameters. This works on 1997-2000 boxsters. Same as 996....
To switch from F to C:
Hold down the recirculating button then push both the temperature + - buttons.
To access diagnostics:
Hold down the Recirculating & Air up buttons for 5 seconds. The + - buttons go up and down through the list of "c" codes. The center vent button switches the left display between the "c" code and its actual value. Press the Auto button to exit.
I have yet to verify all these, this info was copied from wonderful people on PPBB!
Here is a list of what can be seen:
0c - ERL
1c - Oil Temp?
2c - Inside temp. Sensor mounted in the aspirator assembly at the side of the dash.
3c - Outside temp. Sensor located inside the air inlet of the A/C unit.
4c - Outside temp. Sensor located in front grill of the radiator. The data is fed to the Climatronic from the instrument cluster. When not moving, the instrument cluster OBC temp display retains it's last setting until moving. This is to prevent heat emanating from the radiator affecting the temperature sensor. The A/C unit uses the lower of the two outside air temp values in determining fresh-air temp.
5c - Outside temp. (matches OBC outside temp display)
6c - Coolant temp.
7c - Footwell discharge temp.
8c - Sun sensor (dash top)
9c - Sun sensor.
10c - Passenger compartment fan speed.
11c - Passenger compartment fan voltage.
12c - Temperature mix Flap command 1=COLD, 100=HOT
13c - Temperature mix Flap position
14c - Central Flap command
15c - Central Flap position
16c - Footwell/Defrost Flap command
17c - Footwell/Defrost Flap position
18c - Recirculation Valve command 1=OFF, 100=RECIRC
19c - Recirculation Valve position (feedback)
20c - Vehicle speed in kph, updating only once per second. (real speed, not speed+safety margin as in the speedometer)
21c - Engine RPM in hundreds. This too only updates once per second.
22c - ?
23c - ?
24c - Sun sensor, exterior lights switch & panel lights control (term. 58 & 58d voltage) - used for A/C panel display illum.
25c - ?
26c - ?
27c - ?
28c - Fan speed?
29c - ?
30c - Engine run time in seconds (255 max.)(=0xff)
31c - Timing counter
32c - Displays test
33c - Software version? Mine states 3.4
34c - ?
35c - Outside temp. from inlet sensor (filtered?)
36c - temp?
Gerdou
Gerdou
  • 6597 messages
  • Prénom:Gérard
Impressionnant j'imaginais pas que cela soit possible
Guest_pywash_*
Guest_pywash_*
Maintenez les touches et recirculation d'air pendant 5 secondes
quelle touche ??
Edelrot
Edelrot
  • 10334 messages
Voici le document en français.  ;)
Edelrot
Edelrot
  • 10334 messages
Guest_pywash_*
Guest_pywash_*
nikel merci ca marche super bien:)
J-C
J-C
    986-Club
  • 2085 messages
  • Prénom:Jean-Christophe
  • Modèle Porsche:Boxster 986
Très intéressant , merci Pascal ...
Wouah!
Je savais pas.
Respect, les gars! ;)
  • 40399 messages
Merci Pascal! Je rentre du resto...
Attention tout de même ça ne fonctionne que jusqu'à 2000...
Pour info, ça fonctionne aussi sur certaines Audi de la fin des années 90...
Edelrot
Edelrot
  • 10334 messages
Je n'y suis pour rien. C'est un document dispo sur le serveur de Frex. ;)
jean-david
jean-david
  • 394 messages
  • Age:37 ans
  • Prénom:Jean-David
  • Modèle Porsche:boxster 986 phase2 & boxster 987 2.9
  • Kilométrage:47000 km
mince la mienne est de 2003 suis dégouté
  • 40399 messages
Ne soit pas dégoûte, un câble Durametric te donnera les mêmes paramètres...
Guest_fouedou78_*
Guest_fouedou78_*
Bonsoir alex j'aurai aimé savoir si tu était disponible cette semaine pour un coup de valise ?? Et par hasard si tu connais un indépendant compétant en île de France car la je craque vraiment merci beaucoup pour tout les conseil bonne nuit
  • 40399 messages
Je peux me rendre disponible Cette semaine...
Guest_fouedou78_*
Guest_fouedou78_*
Je suis disponible quand vous voulez
Guest_fouedou78_*
Guest_fouedou78_*
